Ric
- May 7, 2010
- Threads
- 139
- 5,765
What brand oil do you use to change your hydro oil? I have a raptor sd with zt 2800 pumps. the manual says use 20w50 sl/sm it doesn't say anything about synthetic or not. does anyone know what they are filled with at the factory. I ask because my overflow is empty and i want to fill it up to the cold line.
Do and use what the manufacturer/ manual calls for, if it calls for a synthetic then use a synthetic if it calls for plain old 20w50 then use it. I ran the 2800 drives for 1400 hours total and used the plain 20w50 and never had an issue. I wouldn't recommend changing viscosity. If your manual doesn't say anything about synthetic then I wouldn't use it.
