Never again
Ric
Never again will I buy a B&S anything.
When a blade adapter with a built in shear pin can do this to a crank instead of shearing the pin itself it's a sad thing for the manufacturer.
Ric
What machine was that on?
A 175cc, 775 series Electric start Briggs and Stratton which is now junk. :thumbdown: The motor runs great I just can't put a blade on it.
Nwatson99
Was it hardened key-stock in it instead of the soft to shear out?
Lawnboy18
That is rather odd.
Was this on a Cub Cadet push mower?
Ric
Cause, blade bolt came loose.
No the blade bolt did not come loose. It was secure when I removed the blade. The blade adapter turn about 1/3rd the way around the crank shearing the crank before the adapter broke.
