Pony won't start
Me4ble
I have a nine year old Pony and just a couple of weeks ago, my mower decided it would not start. The engine turns once or twice, then stops. It doesn't turn over. I replaced the spark plug and battery but no change. I cleaned the air filter and no change. I am not super knowledgable in small engine repair but want to try to fix this myself if at all possible. What should I do next?
It might help to wait till its day light out if your flash light is faulty. Look at your battery and you will see a +/ red and -/black where the cables are connected. Start on the -/black side and follow the cable till you get to the spot its fasten on the frame. Remove this cable and clean very well. A very good chance you will find that the cable where it is fasten to the battery on the +/red side is the trouble spot.
Ok - so I cleaned where the battery cable connects to the frame. It was dirty. However, nothing changed.
When I took out the spark plug and turned the key the spark plug sparked and the engine spun like it wanted to start. However, when I disconnected the spark plug wire to re-insert the plug, the metal connector inside the rubber end broke off on the spark plug.
Now what?
