Power Inverters
jekjr
Do any of you have any stories on successes and or failures using power inverters.
I have a 1500 watt inverter that I keep in my truck that I have used many times in the last 7 or 8 years. I have run an electric chainsaw, electric hedge trimmers, an air compressor, an electric impact wrench, and numerous other things with it.
One time the power was off and I used it to keep the fans running and the curing light working in my windshield crack repair shop.
BHLC
Do any of you have any stories on successes and or failures using power inverters. I have a 1500 watt inverter that I keep in my truck that I have used many times in the last 7 or 8 years. I have run an electric chainsaw, electric hedge trimmers, an air compressor, an electric impact wrench, and numerous other things with it. One time the power was off and I used it to keep the fans running and the curing light working in my windshield crack repair shop.
We have a 3500 watt that runs the microwave! Haha!
mullins87
I think they are very handy to have. Only thing is you have to always be mindful of the amperage draw on your battery.
jekjr
The 1500 watt was a bust as far as running the air compressor. Might have been the battery was not big enough. I tried it on the battery in my camper.
The battery is only a few months old. Anyway I scrapped the idea.
briggs
I have a 1500 in my truck I use it in the felid works ok for what it is
jekjr
I use mine pretty often as well from the batteries on my truck. I have a Dodge 2500 with a Cummins. It has 2 Battteries. I was trying to use it on a trailer with a deep cycle to operate an air compressor.
mullins87
Did it run the compressor for a short time, or did it not run it at all? If it only ran for a short time, then your battery capacity is too small. If it didn't run at all, then either get a larger inverter or a smaller compressor. I have a 3,000 watt inverter than ran a small compressor long enough for me to build a workbench and lots of shelving in my outbuilding. That compressor is great for airing tires and such, but it was barely able to keep up with a framing nail gun if I didn't get in too big of a rush.
jekjr
It would not start it. The compressor would try to start but would not run on it. I use the inverter at times with my small compressor hooked to my Dodge pickup. It has two batteries.
briggs
Mine is on my blazer I use it to run my grinder ,electric impact,chagre my drill,Saws all and a lot more ,,,If I want to use my compressor I take my small one and my champion generator but I don't use it much makes to much noise lol .....I hate using my compressor in the shop to it drives me nuts lol
I have been looking at several options lately including solar panel systems.
