txzrider
- Apr 24, 2012
- 392
As far as your prep time goes your on the right track. Instead of ripping off the down spouts why don't you install them at a height that will not hinder your mowing instead of screwing around with them every time you mow and yes throw the hoses and sprinklers away and try installing a under ground sprinkler system with a timer to turn it on and off like you should and would it be possible to make or teach the kids pick up there own toys and put them away when there done playing with them, there are a few more ways you could cut time off your list of complaints but I guess doing things with the right tools would be out of the question. As far as the mower clogging because it's a POS, that's a lot of bull because if a person knows how to set up the mower, mow his grass at the proper height the mower will work perfectly the way it's designed to. The thing is the timecutter nor the 30" isn't going to help you one bit because your not addressing your list of complaints at all. I guess it's like the old saying goes, You can't help those who can't or wont help themselves.
Ric did you get up in a bad mood today? You seem a bit harsh! He said he is mowing parts of his yard 3 times a week... its not like he is letting it get overgrown. Also he stated he has 3 kids under the age of 2! I have no problems believing he would spend more time herding them around than just picking up toys himself. Not that it would be a bad thing to have them learn at a young age to put away their toys! Sprinkler system seems like a great idea, epecially if he goes for a 30 inch mower and saves 1500 vs the ztr. I have had several mowers over the years that clogged no matter what I did. Sharp blades helped, keeping the underside of the deck spotless helped ... but nothing would solve it. That being said I have 1 more comment about the ztr... will you ever have a need to pull a cart around the house? I use my ztr to move my trailers around, to pull a cart with salt for the pool up my hill from the truck, etc... last comment about the ztr, I would not plan for more than a 50% time savings on the actual mowing time! unless you are a very slow push mower... Which I am, but still cant cut off more than half the push mowing time.
