abelw44
- Aug 20, 2013
- 54
Hi all,
I recently removed the side cover (sump cover?) on the engine of my atco qualcast suffolk punch 35s mower. But stupidly, I forgot to put any timing marks on the gears. as far as I can see only one gear (the main one) has a timing mark but even that is not actually on the gear it is on the drive shaft. the other gear has a hole drilled in it but I don't know whether this has anything to do with timing? Is there anything I do to rectify the timing, or is trial-and-error my best bet?
thanks
thanks
