Brucebotti
- Jun 9, 2011
- 297
I will begetting my New Toro MX5060 delivered on Wednesday and I have a few questions. I would post this in the Toro Forum, but they are general questions pertaining to the Kawasaki twin motor and the Z-2800 transaxles.
1. The owners manual says to use either some special Toro Hydro Oil or 20w/50 motor oil in the Z-2800 transaxles. Which do you guys use? If you go with the motor oil, do you use conventional or synthetic?
2. The owners manual says to turn the PTO on, and off at full throttle? Is that correct? It seems like that would cause problems. I'm guess it's okay if that's what Toro recommends.
3. The owners manual says to turn the ignition off at full throttle. This definitely seems like it would cause problems.
Thanks in advance for all your assistance.
Bruce
Bruce
