jpollman
Hi folks,
Last April I picked up a Gravely ZT52 HD and I LOVE it! It works better than I would have ever imagined. I used it all last summer and toward the end of the summer, I changed the oil and did any maintenance as per the schedule. I was just about done with fall cleanup when it was time to change the hydraulic fluid. Being that it was getting pretty cold and miserable, I decided to wait until spring. Well spring is here and I'm ready to do the job. I've got the materials and the manual. It looks pretty straight forward and not too difficult. The only question I have is filling the transmissions. After all of the fluid is drained and the new filters and guards are installed, it's time top refill it with the 20W 50 motor oil. I know you leave the upper plug out and fill each trans until the fluid just reaches that point, and then reinstall the plug. But the only question is where to fill it from. I'm assuming that you just pour the fluid into the expansion tank and the oil will run down into each of the transmissions. Is this correct? Once the oil reaches each of the upper plug holes, I reinsert the plug and then follow the procedure for topping off the fluid. Which is nothing more than filling the reservoir to the proper level. Then purge the system and I should be good to go.
Thank you very much for any input!
