toro
mikey
Hello.New member here.I am going to purchase my first zero turn mower soon and would welcome any recommendations/advice on the toro mowers.I have only a 1/2 acre lot,but would consider a little overkill in size if more comfort is involved as I have knee and hip issues.also,I would like a tutorial of 2 blade vs 3 blades.Thanks
Go to this website a see if any of the 42" models fit your needs. All are good units and will hold up well.
Toro | TimeCutter SS - Zero Turn Lawn Mowers
Basically the number of blades the deck is based on the deck size. I personally have found that the lower number of blades the better the cut. Also, the larger the blade length, the harder it is to side discharge.
MowerMike
I Personally would buy the Titan it's a lot more mower than the Time-cutter SS
It's a lot more expensive too. What are the major differences, and why would a homeowner with a 1/2 acre lot need it ?
If it has a Fab deck that would be why I would choose it over the others they hold up way better.
Ric
True the Titan is a little more expensive but you are getting a 10 gauge Fab deck, a 5 gallon gas tank not a 3, Comfort is something he said he would like to have and the rear 20x10 tires along with the adjustable seat spring suspension is something the OP could benefit from and the titan also runs the Hydro gear 2800 transmission which is twice that of the EZT in the SS and the titan also runs at 18000 bts which would give him a better cut and if he likes the looks he also has the ROPS. The OP said he only has 1/2 acre lot, but would consider a little overkill in size if more comfort is involved as he has knee and hip issues. The Titan IMO fits the bill for what he is try to find in a Toro mower. If he wants more comfort I would suggest he look at a Full Suspension Ferris but it to runs more money than either of the Toros.
IS 2000Z Overview
djdicetn
IS 2000Z Overview
mikey,
I would go as far as to recommend stepping up still one more model in the Toro line based upon your comment about knee & hip problems. Even though you would'nt be mowing for extended time with a half acre, the Titan MX4880 adds a Full 3D Isolation suspension seat which would be noticeably more comfortable than the spring suspension on the ZX series. Again, it will be a little more expensive but you're the one that is going to be mowing with it for many years to come. I "almost" went with the Titan MX(or the Z-Master 200 series) Toro myself last fall before purchasing my Gravely. Believe me, a full suspension seat is something worth getting up front. Below is a link to the MX4880 in case you want to consider it(also, the MX upgrades the HydroGear ZT-2800 to the ZT-3100 trannies for even more commercial quality durability as well as a 400Hour Warranty versus the ZX's 240Hour Warranty).
Toro | TITAN MX4880 - Zero Turn Lawn Mowers
I would agree with Ric and go with the ZX series. I only suggested the TimeCutter due to the size of the lawn. The MX series is way to much over kill and not worth the expense.
djdicetn
Mikey,
When I looked at the 2012 Titans, the 54" MX was $900 more than the same size ZX model. The 48" is probably less difference than that. To me the "Commercial" ZT-3100 trannies, the suspension seat and the additional 160hours on the Warranty added up to more than the $900 difference. Of course, it's your money but I would recommend you drive each over some rough terrain and see if the spring suspension on the ZX is comfortable considering your hip problems.
Ric
Mikey,
Hey didicetn, we were talking about seat comfort, read the following either were screwed up or Toro is cause they both appear to be the same seat :laughing: There using the same write up :confused2: the only difference I can see is the 4820 has a retractable seat belt that comes standard
Contoured 18" (45.7 cm) Extra Tall w/ Slide (ZX 4820)
The premium seating system on the TITAN is truly a leader in comfort. The extra thick seat foam is contoured to envelope the operator in comfort and help hold you in place when traversing rough terrain. The seat is further cushioned by a unique adjustable seat spring suspension allowing you to have anywhere from 2 to 5 springs underneath the seat to give you customized support. A four-inch (10.2 cm) seat slide is adjustable while seated to help give you just the right fit. Adjustable armrests and retractable seat belt come standard.
Premium Toro Seat (MX 4880)
The premium seating system on the TITAN is truly a leader in comfort. The extra thick seat foam is contoured to envelope the operator in comfort and help hold you in place when traversing rough terrain. The seat is further cushioned by a unique adjustable seat spring suspension allowing you to have anywhere from 2 to 5 springs underneath the seat to give you customized support. A four-inch (10.2 cm) seat slide is adjustable while seated to help give you just the right fit. Adjustable armrests come standard.
