jenkinsph, As I stated the fit and finish of the JD is superb but throughout the 300 select series the JD drive is vastly inferior to the Hydro Gear BDU.
However I am curious as to why you consider the Kanzaki K58 sealed drive which contains approximately 2/3 LESS hydro fluid and which has a very low weight on axle rating to be superior to the BDU-could you give some specifics? Aside from the fact that the 58 has an ALUMINUM case and ALUMINUM gears.
