Fair enough but read on-by the way I was in error, the rated capacity of the K58 is 329lbs.
Four gallons of fuel is about 24lbs, shall we say the operator is 200lbs?, total of 224lbs.
So even at a 50/50 split : tractor weight 681 / 2 is 340, operator-200lbs?, now 540lbs, fuel is over the rear, another 30 lbs, 570, so while the number is better its still bad; from 16lbs all the way up to
59 lbs,
Another 4 stone for only $1,600-those are some expensive rocks.
Can you see why the k58 is so popular for the upgraders :laughing:
Are you seriously going to say that the K58 doesn't blow big time??
And by the way chev, the weight rating usually is static, think of that all you 58'ers every time you hit a bump.....
