mhavanti
- Oct 12, 2014
- 12
- 924
If you're looking for a riding mower first thing I do is look for bolt on rear wheels. If you have to use a torch to remove the wheels after a minute. You are going to have much more work than simply hitting the lug nuts and gaining access to the axles. Not that is necessary often, however, it is cheap to cut a spline.
There are things you look for on a zero turn as well. Sealed bearings are a must. I don't believe there is one unit out there that has every item we all want in one mower. If so, I haven't found it and the prices have gotten ridiculous no matter the buy in level you're looking for.
