Towing moving without starting
gary sr
I have a grasshopper 725 front deck mower and need to load it on a trailer. my question is how or what has to be done to make it possible to push or pull it. I have finally faced the fact that it's going to take someone other than myself to find out why there's no spark. all help is greatly appreciated.:confused2:
mlh727
There is a dump valve under each hydro. Use a 5/8 wrench to turn counter clockwise one revolution. This will allow each side to freewheel. Just don't forget to tighten them back up! :cool:
gary sr
would that be a brass colored bolt head with a hole thru it cross ways? maybe an 1/8" hole?
mlh727
I don't remember if its brass or not, but its at the bottom. Just turn it one turn and it should release the wheels. Don't take it out, just loosen it.
gary sr
thanks alot. same way a dixie chopper release's
