I have a L110 that when you turn the key, the mower does absolutely NOTHING. The lights DO come on, and the hour meter DOES work, but other than that there is nothing. No "trying" to start, no clicking, absolutely NOTHING !!! I have owned this mower for probably about 10 years and never had this problem before. I HAVE had the problem of the starter solenoid going out, but I have replaced the starter solenoid and that does not fix it.
Is there a switch of some kind on the brake pedal ??? Since that pedal MUST be pushed in before the mower will start......
SOMETIMES (maybe 1 out of 10 times) I can keep the pedal pushed in, and rock the mower back and forth while having the key turned, and WHALLA..... it will start. BUT like I said, that is only 1 out of every 10 times. Couldn't get it cranked at all yesterday
If I jump the terminals on the starter solenoid with a screwdriver, it will start up. But I have THREE different starter solenoids, one being BRAND NEW, and another "confirmed" good one, but even if I replace the solenoid, it does NOT fix my problem.
WHAT GIVES ?????????
