steelroy
- Jul 1, 2012
- 2
- 8
I have a Sears DLT 2000 917.272246 with a 20 hp Kohler. Lately it would start and will run but needs to be partially choked to stay running. The motor won't start now even with full choke. The fuel pump is ok. I took the top plate off and checked that jet tube and it's clear. I dropped the bowl to check the float and it appears to be ok. I pulled the solenoid. Is there a way to check it's operation?? Because I tried to fill the bowl using the gas line and there's no flow. Thanks!
