Lets see I bought the mower used, after a year the mower had a knocking sound, I broke down the engine and rebuilt it, new lower, bored out the upper in installed a nice sleeve then put everything back together and then ran into problems with torquing the head down, it seems the specs that I found called for 30 ftlbs on the four bolts in a cross pattern, but it seemed to loose so that there was leakage out the bottom on the mower frame, so I replaced the gasket with a new one, torqued it down a bit more, and still a little leak, so I would start briefly and torque it down bit by bit until there was no leaking, and then buttoned it down and it worked well all season aside from a governor problem. Now this season on the second mow it started to spray gas our again. So what gives, am I not getting the right torque, or do I have a warped surface? I checked all that when I had it apart and it all checked out seemingly. Also ever since I rebuilt it I cant seem to get the governor right, its either working or its revving out of control and I have to bring the throttle all the way down to slow it down, its a constant up and down with the throttle to get it right. Now im no small engine professional as this was my first engine rebuild for combustion, I had my neighbor over seeing it, did a lot of research and stuff and part of it was for fun.
So does anyone have a torque spec that is for sure accurate? I mean 30lbs seems low, as an aluminum bike stem is often torqued to 45lbs. And for the governor, I think its likely something is hung up on the inside of the case maybe? I need someone with experience here to offer some direction. I just not sure if this is something systemic that im overlooking here.
Oh and im new to the forum thanks guys
Collins
Collins
