I REALLY NEED SOME HELP
Tedws
:confused3:I HAVE A CRAFTSMAN 917.255720 10 HP TECUMSEH ENGINE, THE ORIGINAL ENGINE WAS 143.356012, THIS ENGINE HAS BEEN REPLACED WITH 143.406022. THE CARB. IS A 632525 AND I HAVE CLEANED IT 4 TIMES EXCEPT BEHIND THE WELCH PLUGS. MY BIGGEST PROBLEM I AM HAVING IS (I MUST HAVE THE ONLY 1985 TRACTOR 917.255720 IN THE COUNTRY) BECAUSE I HAVE BEEN TRYING TO FIND SOMEONE TO TELL ME HOW TO HOOK UP THE GOVERNOR. THE 1985 YEAR HAS A NEW GOVERNOR SET UP AND I NEED TO KNOW WHAT PARTS AND THE LENGTH OF THE PARTS AND WHAT HOLES EACH OF THOSE GO IN. I HAVE SEEN PHOTOS IN A NUMBER OF TECUMSEH MANUALS AND THEY DON'T TELL THE LENGTH OF THE SPRINGS OR THE LENGTH OF THE SOLID ROD OR RODS AND WHAT HOLES THEY GO IN.I HAVE LOOKED ON THE INTERNET ON A NUMBER OF FORUMS ,YOU TUBE AND CAN'T FIND ANYTHING. I AM GOING TO TRY AND SEND SOME PHOTOS OF WHAT I HAVE. THANKS FOR ANY HELP YOU CAN GIVE ME.I HAVE BEEN TRYING TO GET THIS INFO FOR THE LAST 2 YEARS OF AND ON. These photos are all of the new engine the 143.406022
silver1
I added some picture of mine. TVM 220-157069E motor. The carb. I got to work was a new one for a snowplower! Manual choke!!!! Enjoy:cool:IMGP0032-001.JPG932991.JPGIMGP0040.JPGIMGP0151.JPGIMGP0152.JPG
Fish
You need to find and post the numbers off of the engine, so we can find out which exact Tecumseh you have, the number will start off with "143."...
Fish
OOOpps, I see it now that it came back up, let me do some digging...
Fish
But I see that you have said "the original engine" was 143.356012, and the engine was replaced with "143.406022"........
So are we looking at engine 143.406022, or a cobbled together bunch of parts from both?
Tedws
The 143.406022 is a total replacement engine that I purchased from Sears . Tedws
Fish
Then how/why is there any problem?
So was the new replacement engine anywhere in your pics, or did Sears smear all of the old dirty grease and paint all over it? I see one newish carb, am I missing some pics?
Tedws
No sir I am just not explaining very well about 1997 I broke the reverse chain in the transmission and my wife purchased for me a cub cadet so I parked it in the grage and some time back I got a reverse chain and put it in then I had a few hospital stays which put every thing on hold.The engine was new when I purchased it back before 1997,and because I could not get the transmission to work I parked it again. In the meantime I have misplaced the diagram of the governor so I do not know how to hook it up and also I I have no control with the throttle on the dash and when it rus the RPMs where really high.So the dirt is from where I did use it before the transmission problem. The dates may not be just right but they are close. I trying to get it running I have a use for it now and since I purchased it new in 1985 I thought it would be worth getting it going. Thanks for your help. I am not a good speller. By the way I am 73 years old.
Tedws
This engine was run for about 6 months after I got it an then the tractor was stored for about 15 years
