Where Coxy Rests & Re-charges
A few pix of Coxy's garage, where the charging station is located.
There's some sheet steel on the underside of the pool deck, to keep the garage dry.
The door / flap opens up to allow human access.
Coxy sneaks in and out, underneath it.
Another oddity I've noticed is that Coxy fires up the blade disc motor, immediately
prior to leaving the charging station, then shuts the motor down, before backing
out to get to work. As you can see, that results in grass shavings acumulating
on the charging station plate. No big deal to take a broom and sweep them off,
every so often, but I do wonder at the behaviour.
The lid isn't properly located on the charging station head because of the incorrect
spade connectors supplied. I'll remedy that when I can get some insulated flag-type
spade connectors.
