Thanks fanatic. I recently just upgraded it with a steel rod for the pivot point, another 2x4 on the back and 45deg. angle supports. works alot better now.
the plow itself angles. you take a pin out and move the plow angles to the left or the right. its not in the mount itself.
How does the angle plate attach to your push arms?
tomorrow i will try to get pictures to show you now how i did it. its kind of dark now:laughing: i also have a weight box for my tractor too. i recently just put a redneck rigged support on it too. screwed a random 2x4 i found with nails sticking out cut an angle to hook onto the ball hitch mount on the back and screwed it through the bottom of the box. i just put rocks in the back for extra weight. you have any pictures of your plow?
