govenor spring
steve19438
i need one. sears.com no longer carries it. part no. 232 from manual.
anyone know where i may get one?
thanks.
Please post the model number of the engine. Would greatly help us help you.
steve19438
the engine is a B&S I/C GOLD model
how do i post a photo of it here ?
pugaltitude
What you need to give is model, type and code of engine.
It should be stamped on the blower housing.
steve19438
ok so what does a "blower" look like on one of these little engines?
thanks.
It's the housing covering the engine.
Here is the Briggs part number you need. #691842. You can take this number to any repair shop and they should be able to get it for you.
steve19438
many thanks!
while your at it i may need another part. it is a plastic L shaped part that fits over a nipple on the carb. and the fuel line is attached to it. the manuel says it is part 611. any hope for a part number on this one ?
Go to this web site and it will give you all the numbers you need.
Briggs and Stratton USA
Type in your model number under the parts lookup, and you will find your engine.
