I am not sure what parts need to be removed to get the carburetor out.
This is what the service manual says about the uninstall process.
Carburetor Disassembly/Assembly-FH541V,
FH580V
紐efer to the illustration for disassembly and assembly. 謬here are several passage plugs (Ball plugs) in the carburetor
body. Do not remove them. 稗efore disassembly, mark the out side of choke valve and
throttle valves for assembling them. 紐eplace the pilot screw with a new one if necessary in
accordance with the following procedure.
○Carefully mark the position of the pilot screw limiter on
the carburetor body so that it can be installed and set to
its original position later.
○Remove the limiter. Be careful not to turn the pilot screw
at this point.
○Turn the pilot screw clockwise and count the number of
turns until screw is gently seated in the pilot passage.
Record the number of turns needed to close the screw.
○Turn out the pilot screw to replace it with a new one.
○Install the new pilot screw until the screw is gently
seated. Then open the screw the same number of turns
as recorded prior to removal.
○Align the limiter with the mark on the carburetor body to
install, taking care not to turn the pilot screw. 肘nstall the choke valve and throttle valve on the shaft as
the outside mark of them facing outside. 疋rive the float pin into the carburetor body. The big diameter
side of the float pin must face the choke value side. 柊ssemble carburetor parts with recommended tightening
torque (see Exploded View).
1. Limiter
2. Pilot Screw
3. Spring
4. Spacer
5. Low Idle Speed Screw
6. Spring
7. Screws
8. Throttle Valve
9. Throttle Shaft
10. Dust Seal
11. Choke Valve
12. Choke Shaft
13. Dust Seal
14. Solenoid Valve (Electric Starter Model)
15. Gasket
16. Float Bowl
17. Gasket
18. Float Pin
19. Float
20. Main Jet
21. Main Nozzle
22. Float Valve
23. Gasket
24. Screw (Other than Solenoid Valve Type)
Here is an attached picture of what I am seeing.
