blowertech
- Jul 1, 2018
- 1
- 3
Hello,
I have a Ferris IS4000 zero turn with the 31hp briggs engine. The oil pressure/coolant temp alarm goes off after maybe 5 minutes of run time. The oil pressure and coolant sensors test fine. I do not know how much oil pressure it has only that the sensor is activating when it is started and both are ok when I check them with the alarm activated.
I was told to change the PTO switch last summer when this happened and it did fix the problem. Could this switch be bad again or is there something else that I should be checking.
Thanks, blowertech
Thanks, blowertech
