I have a Cub cadet rzt with a 22 hp v-twin kawasaki. Last year it was getting hard to start and I found that the spring fell off the auto decompression on the cam. This week I replaced the spring put everything back together. New battery, gas, fuel filter, cleaned the carb, cleaned the coils/gapped them, and adjusted the valves. Of course it took a little while to get it started with all the lines dry but it finally started up. I took it for a spin then parked it. I waited about 10 min and started it up and it started fine. Waited an hour and it started. Next morning it will not start. It has spark. Fuel will fill up the air filter bowl area as i try to start it. Is that normal? I dry the excess fuel out and try to start it again and it continues to fill up with gas there. Im not sure if this is coming from the unburned fuel in the cylinders or dumping from the carb. If i continue to crank it will backfire through the carb with a big bang.
Ive pulled the carb apart 3 times and cleaned it. The float seems to be working fine. No cracks or fuel in the float.
