Hi,
I got a Tiller from a yard sale that had been sitting a while. Took out old gas, and put in fresh.. Put a new spark plug in (RC12YC), checked gap at .030". Won't start.. Checked spark and it looks good & strong. So sprayed starter fluid in and it revs/runs for a second or three, but won't run. Took off carb and sprayed it out real good with carb cleaner and all the jets seem to be open (squirt it in one place, and see it come out another). Bowl is filling with gas. Replaced gaskets and the needle valve seat in the carb. Compression seemed good sticking my finger over the spark plug hole, but ordered a tester to test it (arrives Tuesday). I took the valve cover off and the valves seem to be operating fine.
What's my next step? Just get one of the aftermarket carbs and try it? What else should I check? Is it possible for the timing to be off?
Briggs and Stratton 126312-0580-B8
Thanks!
Thanks!
