Good n Dusty
- Jun 26, 2014
- 3
- 20
Hi fellow grass cutters. I have a John Deere 1023 w/loader and quick attach mechanical lift 60"mower deck. My problem is that there is a piece of iron about 7" long sticking out or down below the bottom edge of the mower deck. I assume that was put there to stop one from cutting into rocks and stumps and such. The problem is that it also plows the ground when I try to cut low or on uneven ground. Is there anything I can do to remedy this without the obvious of not cutting low or stay on level ground? Thanks for your input.
Baldy.
Baldy.
