Walk behind Mow Faster
lizard
So, do you think Dwyer Felton is going to come out with a diesel walk behind mower?
I like the idea of the two-stroke diesels but I just don't know that much about them. One thing I read said that they tend to be heavy -- good for marine applications, etc. I also read that they don't use the crankcase to shoot the fuel-air mixture up to the combustion chamber. The fuel-air mixture is pumped under pressure -- sounds similar to a supercharger.
Detroit Diesel(GM).........are a two stroke supercharged,turbocharged Diesel........they have maximum torque at 1100Rpm and high idle of 2100Rpm.......these are Truck engines.
The car diesel engines are lighter even some have aluminum Blocks and heads..........but Steel Liners.........they have come a long way .........have a look at mercedes Benz.........racing their Diesel engine powered race cars.
Dwyer Felton........only have petrol honda.........they should look at diesel.........as the more they weigh the better.
Two-Stroke
Audi had fielded some turbo-diesel race cars recently. Some of that technology has filtered down to their consumer line.
lizard
Audi make some awesome diesel turbo sedans............but they cost serious money.........stick to the VW Golf.......good Diesel:eek:
Two-Stroke
Actually, it's the Jetta TDI that I've been thinking about -- but it's just a thought.
lizard
Like I said before.....a Jetta is a Golf with a boot...............it is not a hatch...........but a sedan...........which is better...............hate hatchbacks:mad:
Two-Stroke
I'm not absolutely sure -- somebody help me -- but, at least in the US, the Jetta is a different car. It's larger than the Golf -- not just sedan vs hatchback.
lizard
Yeah the Jetta is a tad bigger.........but they have got 6 speed auto tranny.........320nm torque turbo diesel
lizard
Mow your lawn at the right height and speed, as well as having protective gear on, ie. Gloves Full face Protectors and Fully clothed........and Steel capped boots.
Many a Rotary mower has taken Toes and fingers off careless People.
Remember mowing can be dangerous if you do not take precautions..........death or serious injury can occur when you least expect it..........bit like Insurance...........you never know when you may require it.:eek:
lizard
Warming up this week the Honda is still doing 4,500 Rpm..............has not blown yet.............but time will tell!:eek:
Two-Stroke
I used full safety gear over the weekend while cutting, splitting and stacking wood -- still managed to mash my finger.:mad:
