Walk behind Mow Faster
Two-Stroke
Reel mowers can cut in the wet better than a rotary.........just the mess of clipping when they are wet.....plus you can tighten the clearance between the bottom blade and reel to zero clearance as the lawn is wet and is lubricating and keeping things cool..........and it cuts better.:eek:
That makes sense. I do know that rotaries don't do well in the wet -- I just wait for the grass to dry, at least somewhat.
lizard
Rotaries get blocked up in the exit chute in some mowers as it is too small at is a drama.......some rotaries are better than others in the wet.
But sometimes you have to mow when it is wet or raining.......lol:eek:
Two-Stroke
True -- two-stokes spin faster and with more power so they're less prone to clogging.
I never mow when it's actually raining but occasionally when it's still a bit wet.
lizard
:eek::eek:
Never under estimate a 2 Stroke...........4 Strokes are so so ........thats it
Two-Stroke
:eek::eek:
OK, getting back to "Walk Behind, Mow Faster", don't you think that the ultimate reel walk-behind mower would be: much, much lighter, therefore (a) powered by a two-stroke; and (b) made of a lighter metal or even carbon fiber?
I believe you said that your mower is 127kg -- I don't think it really needs to be that heavy. You would appreciate a lighter, more nimble machine.
KennyV
That is how I keep my reel set sharp... but I wet it with valve lapping compound ... and slowly tighten the bed knife toward the reel... dresses the edges out perfect... and even sounds good... :smile:KennyV
lizard
The mower needs to be heavy to compress the lawn to allow it to cut at a perfect level.........7mm as the front roller keeps it stable..........the whole machine needs to be square to cut absolutely perfect.
These 'Reel' mowers cut down to even 2mm.........so you need to know that is perfectly adjusted.........a Rotary mower weighing 30kgs could never ever do this.............remember it is cutting 28 inches wide.............and is a perfect cut.:eek:
Two-Stroke
I didn't know that -- interesting. All else being equal, I prefer a lighter machine. In this case there's a reason for it to be heavy.
lizard
Being self propelled and having a split roller and full differential makes it so easy for anyone to cut a lawn ...Big or small confined area's.......absolutely magic.:cool:
Two-Stroke
They are neat looking mowers. Are they exported or is it strictly a West Australian thing?
