Walk behind Mow Faster
lizard
You know your Honda loves to have full choke to start when cold........if you can start it without choke in halve way position......the filter is blocked.
They run fairly lean so you expect to use a full choke when Cold!:rolleyes:
KennyV
Thats right ...
And that is why you should pay attention to little details like that:thumbsup:... It allows you to know what is not quite right and let you do something about it before you damage your rings by washing the cylinder walls with too rich a mixture...
When something is different or out of the ordinary it bears looking into... :smile:KennyV
lizard
Thats right ...
Trouble with unleaded fuels you cannot tell how the engine is running as the exhaust is always black.
With leade you could tell how lean or rich the mixture was from the exhaust colour.......light grey was good and white was too lean.:eek:
KennyV
That was true... But in the larger cities they were listing smog days that it was unsafe to go out doors... and actually recommended everyone stay inside... Just where dose the inside air come from... ?
I do remember it was bad ... :smile:KennyV
lizard
Well you need to live away from smog......best to live in the Bush.
You are right ......how would it be any better inside.....the air would not be any better or worse.
Water is needed to flush the toxins out of your body..........but lead accumulates.......oh well
thats life will die of something......as long as it not a mowing accident.:eek:
KennyV
I have mostly preferred life in the country... but I like having a city within a reasonable drive...
Unfortunately the city has moved into where I live .. and I am not so happy with living here....
:smile:KennyV
lizard
:smile:KennyV
Well how long have you been where you are to become nearly a city person?
I know its called the Urban Crawl........in Australia........you have too move further away......or suffer like a City person.
You lose a lot of freedom when this happens.........maybe its time to sell and move?:confused2:
lizard
could be....
Nice to see if it is worth doing as you would want to be in front financially....or why bother moving....as it would be a huge chapter in your life.
If you did think of buying something........would yoy want more acres or infrastructure?:eek:
