In the manual for my Toro MX5060, I've come across something that has me confused.
Under the heading it says: "Cleaning the Cooling System": Remove the air intake screen (I have no idea what that is...?) air cleaner cover and fan housing.
Clean debris and grass from the parts
Install the air intake screen, air cleaner cover and fan housing
At first, I thought this was in regard to the air filter and it's components, yet that info is on a completely separate page, with a separate title with different instructions:
"Servicing the Air Cleaner" which goes into how to lift the cover to remove the hose clamp securing the air cleaner assembly to then loosen the hose clamp and remove the paper element.
So what gives?
The info for the above is on different pages, yet seem to address (maybe) the same thing, yet I'm not certain...
Thoughts?
Thanks!
So what gives?
Thoughts?
Thanks!
