- Nov 29, 2014
- Threads
- 64
- 24,727
Yes that will cause the belt to fall offBelts looked ok..took the deck off, everything seems to move freely, although 1 spindle makes a little noise, except the drive pulley tensioner won't move no matter how hard I push, pull or cuss..wonder if that might be my problem
The tension pulley which should be on the run of belt that comes FROM the engine pulley hast to be able to swing on the tension to prevent the belt flapping
