- Nov 29, 2014
- Threads
- 64
- 24,727
Gotch ya.
So it is the 2 week old , thus longer & thicker grass that is overwhelming the deck capacity & bogging down the engine forcing you to mow slowly
And at 90 mows a week I can see why you don't have the time to mow slow .
A PIA but it might be worth trying low lifts on these yards
I gather you regularly swap the blunt blades for sharp ones.
A battery impact should allow a quick change in a couple of minutes .
If it is the volume of grass overwhelming the capacity of the deck then all a bigger engine will do is break belts
The landlord got a Kubota F2440D with a 28Hp 3 cylinder diesel donk, but it does not cut the 2' tall tussock grass any faster than the Cub Cadet 2248 did ground speed wise.
However at 72" it does cut the mowing time in 1/2
The Kubota could cut faster, but it just can't discharge the clippings
We are toying with dropping the blades a bit to see if we can increase the volume of the deck.
