Troy-Bilt Owner Check-In --- Read This First!
GarryB
Unfortunately, I have taken the belt off and put it back on more times than I can count. I have checked, double checked, triple checked the placement. I climbed under the mower, not running of course, and pushed the pedal down to watch the action. The swivel pulley moves freely just as it should, the belt is in the proper locations on the pulleys, but the belt does not get tight even when the pedal is pushed all of the way down. A shorter belt would work, however, the belt that I took off WORKED! The ONLY thing that MAY be different, but it is contrary to rational thinking.....
On the variable pulley at the transmission, I have the lower belt in the lower groove and the upper belt in the upper groove... seems logical and the pictures in the manual show it this way.... but I could be WAY off. You would think that if both belts were in the same groove that they would rub each other and fray, but I'm no lawn mower engineer, just an occasional operator... :cool:
BlazNT
Well I should have looked closer at you tranny. Is the variable pulley moving like it should? I would say that is the problem.
GarryB
It moves freely, and easily, Everything I have read says it is supposed to.
Like I said before, however, It was doing fine before changing the belt, a little slow, but still worked. Both drive belts were original and the lower one was severely worn/ cracked. That's what started my nitemare.
littlebirdy
Hi,
Littlebirdy here! Troy-bilt Bronco lawn mower 2010, Troy-bilt Horse Tiller 1985, Troy-bilt Bronco Tiller 2015
Currently taking apart Troy-bilt Bronco Lawn mower to replace the drive belts.
GarryB
Hi,
Let me know how you do with the lower belt when you get to it, PLEASE, I took mine off to replace it and can't get it to work since.
Garry
littlebirdy
Garry
Will do. I just ordered my belts, trying get the mower deck off now.
PwrPak
Hello ,
Purchased few days ago a Troy Built TB 42 , replacing a Craftsman Model 917.271022 , lol not be able to cut grass in reverse I seen reviews . Well thats been bypassed . So got to get used the Fwd / Rev lever on other side of the rider. So far whats is great .... a Cup holder !!! hahah
red2blue
Hey, folks.
I'm a relatively new, TB 360 875 EX 190cc, owner here.
Got some reading to do before I bore anyone with a trivial question.
jmelton86
New (to me) owner of a Troy Bilt 14AT809H766 and I'm here to get advice on maintainance and repairs as well as learn more about yard equipment in general. I've been a hands-on dude ever since I could turn a screwdriver. I have worked on cars professionally and am currently working on appliances for a living.
Thanks for having me.
