Need Nikki carb help
belair gregg
I have a Wright Sentar with a Kawasaki 25HP FH921V-BS07 with a Nikki that is labeled 150037048 266401 - although the Kawasaki documentation states that I should have a Nikki P/N 621266. I have not been able to find any documentation on the Nikki carbs. I also suspect that the shut-off solenoid is not working. Can it be bench tested?
In any case, the engine has always been had to start - from day 1. It had gotten so bad that I had to pour gas into the carb to get it to start when cold.
Recently I had the cover off the engine exposing the fan to check the resistance of the coils while hot. One thing lead to another and the fan broke and I overheated the engine. This created a crack on the block behind the starter and a huge backfire was heard when it shut down. Backfiring is nothing new - it always backfired when I shut down.
With the crack in the block, oil smoke billowed from the engine and oil was spraying everywhere when I stopped. While on the way back to the garage after the fan broke, the throttle had little to no effect on the speed of the engine - seemed odd at the time, but I assumed the cable was slipping what with all the oil that was spraying around, or that something had come un done.
In the process of repairing the block (with JB Weld - it worked great, so far), I decided it was time to disassemble the carb for cleaning to correct the hard starting.
All is now well. It starts almost immediately, but I still don't have any throttle control. I have confirmed that the choke and throttle butterflies are operating as they should, but I still get no change in engine speed with throttle movement. I'm at my whit's end, PLEASE CAN ANYONE HELP.
Fish
Wow!
So while running, if you manually move the throttle lever on top of the carb open and closed, does it speed up and slow down?
belair gregg
I really can't access the carb itself due to the way the motor is mounted, but moving the throttle lever (and therefore moving the carb linkage), has no effect on engine speed.
Wow is right - I'm confused. I'm wondering if the violent backfire(s) have damaged something in the carb?
mechanic mark
buykawpower.com scroll down for carb.
Kawasaki Small Engine Carburetor 15003-7080 Order now for same day shipping. 365 day return policy. RepairClinic.com
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
"K&T Parts House Lawn Mower Parts and Chain Saw & Trimmer Parts" FH721V
belair gregg
I don't want a new carb - isn't there someone out there that can help?? Why can't I find documentation for the Niiki Carbs on line - there is nothing available. Is it National Security info ??
mechanic mark
Fish
Well how is this then? Which is it? How then could you "confirm" that the choke and throttle butterflies are operating as they should? We would like to help, but the questions should at least make a little sense.....
belair gregg
I can see the choke butterfly and confirmed that it moves with the panel mounted chock knob. If you are familiar with this carb, the throttle butterfly is not visible unless the air cleaner mount casting is removed. I loosened the carb to intake mounting bolts and nuts, but did not remove the carb or disconnect the linkage. By pulling the carb slightly off the intake, the throttle butterfly is exposed. I was then able to see the butterfly move when the throttle was moved.
I'm still amazed that I cannot find any Nikki carb documentation on line!!!!!!!!!!!!
belair gregg
https://www.nikkinet.co.jp/english/ How much more information do you need ? If you read my posts above, I believe all the information you need is included. By the way, how old is your piece of equipment & number of hours used?
Kawasaki Part Number: 15003-7048
I have the exploded view - I have the Kawasaki manual, in print and electronic form - what I don't have are instructions for initial settings for the pilot jets and how to disassemble the float. Any details would be nice - I took it apart, so I know how it goes back together - the exploded view is of little value.
