I just ran across a used Hustler Fastrak with a 48' deck and the 19hp Kawasaki motor. Based on the serial number it is an '09, bought in Sept. of '11 and only has 35 hours on the meter. I'm pretty sure I could get it for less than $3000. Hopefully more like $2500. Anyway, what do you folks know about these? I'm assuming that the Kaw is a good motor. Any known problems with this model?
I'm not new to Hustler. I've got an '07 Fastrak with 42" deck and 17hp Kohler single. It's built like a tack but I'm starting to have electrical issues. Also the 42" deck only cuts a path 36" wide. I've measured. So my current Hustler is seven years old and I mow and for roughly 75 to 85 minutes a cut from late March to Early November. (Giving you a rough idea of hours since it has no meter) The 48 I'm considering is five years old but only has 35 hours by the meter. I think it's a good deal if I can get it for close to $2500 and there are no known problems that would be considered a 'show stopper'.
Any thoughts on the Fastrak 48 with Kaw motor will be appreciated.
Edited to add: I've had no problems so far with the hydros or whatever they are called. Are they usually considered reliable or did I luck out so far? I think the hydros on the machine I'm considering are 2800 series. Model number is 928275.
