The deck clean-out hose port on my deck does seem to be very effective, or at least I don't see much water and/or debris spraying out of the grass chute.
After running the blades for a minute, the area on the ground in the exit path of the chute is barely damp, so I was wondering if the hose port is malfunctioning.
I have 85PSI on a 3/4" ID hose connected to it and I do see some water coming from under the deck on the left-hand side when hose is attached and water is turned on, but little is getting blown over to the chute with the blades spinning.
If never seen the JD clean-out system in operation, so I don't know what is normal and what isn't.
