I first noticed it in high gears, now it does it in all gears. Seems to slip like the teeth on the transaxle gears are stripped, but I opened the case and all the teeth look good, axles are staying in place. The chain seems like it might be a little loose but not enough to cause the trans to slip. Not sure where to go from here. Any good info out there on how to diagnose these? Thanks
