Hi there,
I have an older yardman riding mower with a B&S Vanguard 18hp motor. The motor will start and run for 30sec - 1min then die. If i try strating it right away it won't start, but if I wait a 5-10 minutes it will start and run for 30sec - 1min and die agian.
I have used it 3 or 4 times this season and the first few it was running fine, then the last time it started to get termperamental and wasn't running well. I pulled the carb off and it was clean, though there wasn't much fuel in the bowel.
Any suggestions...
Also what is the selenoid on the bottom of the bowel for?
Thanks for the help
Any suggestions...
Thanks for the help
