I removed the body to get at the remnants of the broken deck level knob. Since I was working on it I also took off the deck and replaced the blades. After putting it all back together and leveling the deck the PTO won't engage. I believe the brake switch is working as it won't turn over unless I push the brake in all the way. I had jumpered the seat switch temporarily but connected that back up. Getting up off the seat while it is running kills the engine. How does mower know when it goes in reverse and shut down the PTO if you are not holding it up? Wondering if I could have messed something up when I took off the forward and reverse pedals. When I first put it back together reverse was not working but after adjusting the position of the reverse pedal I got that working. Appeared it was just not pushing down enough to engage reverse. Is there anything else I can check I may have messed up? This was my first time doing any of this so thinking I am missing something. I don't have a multimeter right now but may have to go get one and check the RIO switch. I did unplug it and plugged it back in.
