I have a Husqvarna 54 inch cut mower that needs a new engine. The old one was a Kohler Courage SV730 25hp which I understand was not really a 25hp from what I read. It was more like a 22-23hp but seemed to do the job OK for me when it was working. The engine experienced a variety of failures last year and appears to have eaten a ring of similar as it is now locked up.
The rest of the mower is in good shape. I had just gotten through replacing some deck spindles and housings and it had new belts for both the deck and mower drive. One had only an hour of use on it when the engine quit. So, I have a perfectly good mower sitting with no engine. I got ahold of a junk mower with a good 18HP Kohler Magnum twin cylinder. I had never seen one of these before but it is an older model that looks like a pancake style engine.
I was originally planning to transplant the 18HP to this 54 inch cut mower to replace the engine but was always apprehensive, figuring this might be too much for an 18hp to handle. I dragged my feet until another variable entered the mix.
I was then given a 16.5hp Briggs I/C powered 42 inch Craftsman mower that had been put out to rot. It had been sitting 3 years but I had it going with minimal cost and time invested. It seemed to be running well so I changed the oil which had been neglected. I have no idea on the history of this unit besides it sat outside for 3 years with no protection but it was likely not cared for before that time either. I was mowing with it after the oil change and all seemed well with no knocks or anything until the engine threw a rod and went out it a blaze of smoke and fire. I put out the fire and towed the mower up near the house to be worked on.
Anyway, I am wondering if this 18HP would be better suited to the 42 inch cut mower vs the 54 inch. As much as I would love to make the 54 inch work, there will be some adaptations required when it comes to fuel supply and the like while the 42 inch would be pretty much a direct bolt on. I have checked the shaft sizes/lengths and all are the same.
Let me know what you think.
Thanks.
Thanks.
