Guys I'm baffled on this one. This mower has been nothing but problems for me.
It boils down to how sensitive my mower is to overheating. The grass clippings from the deck get sucked onto the face of the air intake screen behind the seat, which in turn causes the engine to heat up, which causes the radiator to spit hot coolant/water on your lower back if you don't watch the temp gauge....making you think you've run over a nest of yellow jackets.
Anyways, my wife calls me at work and says the thing keeps overheating and was now blowing blue smoke. I told her to cut it off because she was burning oil at that point.
I get home to find the radiator dry as a bone and after filling that up, I have a hard time getting it to start.
After finally getting it to start, blue smoke pours out of it.....and after about 60 seconds the blue smoke stops coming out of the exhaust but then the over-flow tube coming out of the top of the engine block starts spewing oil onto the ground.
I drained the oil thinking maybe the block was full of burned up oil....but even after filling it back up with all new oil, it's still spitting oil out of that over-flow tube. I've confirmed several times that it is not over-filled with oil.
I'm lost. Did she maybe run it so hot that an o-ring or something worse (crack?) is causing oil to escape a piston? I'm really not knowledgable on small engines, much less diesels.
Anyone have any idea? Here's some pics of the tube in question
This is the tube in question that is now spitting clean oil and some smoke
This is where it goes into the engine block
