PTmowerMech
- Apr 16, 2018
- 396
- 3,018
Some pretty good info in this.
Yeah. The crimper he is using is made to crimp ground sleeves.After viewing the uTube video which I don't normally do. I do see the problem and it is the type of crimpers he is using. It is not design to properly crimp the terminals as it is for a different of connectors like cable lugs. Of course it going not to crimp properly. As noted the solution is to reverse the way the crimping is done. There are proper crimpers out there.
These
18-10 AWG Copper Crimp Sleeve Wire Connectors (100-Pack) SB1810 - The Home Depot
Easy-Twist copper crimp connectors are suitable for use with solid and stranded copper wire from #18 to #10 AWG in grounding, uninsulated wiring, and small motor wiring applications. The pressure crimpwww.homedepot.com
Not insulated terminals. They need one like this
Klein Tools Ratcheting Crimper, 10-22 AWG - Insulated Terminals 3005CR - The Home Depot
The full-cycle Ratcheting Crimper crimps 10-22 AWG insulated wire terminals. This tool features three crimping cavities in one tool with color-coded wire markings for three size ranges of insulated terminals.www.homedepot.com
Like I said. Everybody with a YouTube channel is an expert.
