I have a 18 horse briggs and Stratton vanguard pull rope engine, and a long spring came off and its inside another rod for the carberator and I don't know where it goes?:confused2:
If the spring is looped around the linkage that goes from the governor arm to the throttle plate, the spring will be hooked to the same parts. If there is no second hole on each part, just hook the spring into the same holes as the linkage.
