Or something else entirely?
I've got a self-propelled Husky that just isn't up to the job. It can't handle the sloped terrain, the differing grass densities, and the occasional squishy ground. It stalls, can't climb the grade and is not easily turntable on my terrain. (It'll be for sale here in a bit, would be better for someone with a nice flat lawn)
I was looking at one of the wider cut type mowers with the big wheels. Ariens makes the 911703, or the 911413 (probably overkill for us) or something similar that will have enough power to get through patches of wet ground and wet grass, and be able to traverse or climb a short slope 4-8' that can exceed 30 degrees. The Ariens is the upper limit of my budget at $1,200, so something cheaper would be nice if possible. Self-propelled is a must, I've got quite a bit of lawn. It's too sloped for a riding mower and has some narrow areas that are unsuitable for a true wide-cut mower. Ease of turning would be important, and reverse would be helpful if it's a heavy mower.
Thanks for suggestion and comments!
