Hello guys,
This is my first post.I've got this weedeater that won't run,so far I put new fuel lines in,new fuel filter,rebuilt Carb which is a zama c1u I believe.Also has new plug,has plenty of spark,has about 115 lbs of compression,air filter is good.Even checked flywheel key and its also fine.If I put fuel directly in cylinder it still won't start.By the way I did check flywheel gap to module and it is good as well.Even double checked Carb gaskets and diaphrams everything is correct,fresh gas as well.I feel like I have done all the obvious but this little beast won't run.
What am I missing? I've worked on tons of weedeaters,blowers,mowers ect. But can't get this one to run!
Thanks in advance for any help.I know this is a cheap model but would still like to get it going.
Brent
Brent
