phil.winter
- Jun 29, 2014
- 1
- 4
Hi all. I have had a look through all the threads and couldn't find an answer to this.
I have a Ferris is1550z. The LH wheel power is less than the RH side both forward and reverse. Up hill is quite slow.
The pump arm/linkage movement is the same for both pumps. Forward speed is slower than I'd expect as I have to hold the left lever in the most forward position but the RH lever needs to be just half that of the LH side. As I say, both of the hydro controls do move the same amount.
The engine and grass cutting operation is fine.
I just brought the machine so do not know how long it has been like this.
Any ideas.? thanks.
Any ideas.? thanks.
