Hi Walt,
Thanks for the quick response. I took off the valve cover and when I turn the flywheel, the rocker arms are moving smoothly and look to be undamaged. The engine makes a whistling, woosh sound once per revolution of the flywheel. Does that indicate a problem with compression or is that normal? I tested the solenoid and it opens under 12v. One other piece of info that I forgot to include in the OP; the first time the mower failed to start after stopping in the middle of the lawn, when I went to restart it I got nothing, no starter motor, no turn over nada. I let it sit for about 15 minutes then tried it again. She started fine and has not restarted subsequently but turns over. As far as the PTO switch is concerned, would that be the seat switch? The previous owner had disconnected it so I guess the answer to your question would be no, I didn't turn it off. I'll send you an email for the manual. Thanks much!
Matt
