I have a 52" Raptor with the factory blades which spew grass several feet outside the discharge. Aside from the layer of clippings which can be quite thick if I cannot mow often enough (somewhat beyond my control), it also sends clippings onto the walk drive and patio, which then need to be cleaned.
In addition, I prefer to leave clippings on my St. Augustine lawn (central Texas) so they will decompose and nourish the soil. Therefore I want them to be chopped up as much as might be practical.
So are there better choices for blades other than from Hustler? Could be because of price (if other factors equal) design, or quality.
I have read all the posts I can find for the raptor and mulching blades and it seems that a mulching kit is the way to go.
I would also like to hear specifically from Raptor owners with mulching kits about their experience, especially about the mulched grass as well as under deck build up issues (I only mow when dry, so wet grass isn't an issue in any comments you might offer).
Also interested in opinions as to how important is it to isolate each blade?
Thanks.
Thanks.
