I'm in the process of buying a self propelled walk behind mower. Have a few questions regarding maintenance of walk behind mowers in general.
1. How do the under deck water attachments work? I assume one attaches a water hose and then run the engine to let the cutting blade whip the water around.
... a) Does it really do a good job of cleaning?
... b) Will it have negative effects on the drive belt on a FWD mower?
... c) Will it have negative effects on bearings?
... d) How long to run the engine after cleaning to dry everything under the deck?
... e) If a walk behind doesn't come with a water hose attachment, is it worth it to install one?
2. Will turning the mower on its side to clean the under side of the deck or do other maintenance cause the engine oil to go to places in the engine that's bad? Or can all walk behind mowers be turned on their sides with no ill effects?
Thanks,
YardGuy
Thanks,
YardGuy
