rmcphearson
- May 2, 2013
- 4
- 17
My redmax recipricator will run if it gets gas. It's not getting gas through the carb. I cleaned carb with ultrasonic cleaner and rebuilt it to no avail. When I remove the throttle valve assy and crank the engine I can see exessive fuel being drawn out of the nozzle and the engine will run rich for 1 minute and then finally flood out. So I'm guessing the carb is doing it's job up to the point where the inner idle needle should restrict the gas being drawn out of the nozzle. It must be shutting it off completely. The needle is non-adjustable. What am I missing?
http://www.walbro.com/media/21910/WYAseries.pdf
The only thing I can think to do is get a Walbro metering lever gage and try that but I didn't mess with the lever so it should be close enough at least to run... I think.
I can get a new carb for $120 but I'm using this as a learning process.
-Roland
-Roland
