Had to dissemble engine to repair oil leak.. Hpw should the cam be set on reesembly
R rdklemm Forum Newbie Joined Jul 17, 2011 Threads 3 Messages 5 Aug 22, 2012 / vtec 24 hp brigges cam #1 Had to dissemble engine to repair oil leak.. Hpw should the cam be set on reesembly
C chance123 Well-Known Member Joined Aug 14, 2012 Threads 11 Messages 824 Aug 22, 2012 / vtec 24 hp brigges cam #2 Hand turn the crank to TDC and you will see the timing marks ( . ) on the small gear thats on the crank, and there will be timing marks on the cam. ( .. ) The gear tooth with the "." goes between the teeth that has the ".."
M motoman Lawn Addict Joined Aug 11, 2011 Threads 65 Messages 2,566 Aug 22, 2012 / vtec 24 hp brigges cam #3 Yeah, vtec on an Intek. When do the power grind cams cut in ? At 3800 rpm? Anyway I got it. :smile:
